TwinTurbo.NET: Nissan 300ZX forum - Re: Is the timing belt sitting correctly on the cam gears?
twin3037
on April 13, 2010 at 12:15 PM
posted by Woody75 (Denver)
on April 13, 2010 at 08:14 AM
thanks and yeah i actually took the belt off and re installed the studs. They holes just needed more cleaning out apparently
120k service idler pulley question
twin3037
11:10:51 04/12/10
Not sure what you are describing. Why would the >>>
ZUL8TR
13:15:43 04/12/10
You installed the stud backwards. (n/m)
ZiNnYc
14:27:10 04/12/10
Re: 120k service idler pulley question
twin3037
14:37:08 04/12/10
The pulleys don't sit flush, they need to sit an inch or so
ZiNnYc
14:53:56 04/12/10
Re: The pulleys don't sit flush, they need to sit an inch or so
twin3037
15:02:21 04/12/10
Take an actual picture. (n/m)
ZiNnYc
15:12:40 04/12/10
Pulleys do sit flush. They don't float off the block.
Zarcasm(Hfd, CT)
11:35:37 04/13/10
twin3037
16:45:41 04/12/10
I might have an extra idler pulley around but id have to
5280Z_nightstalker
01:55:47 04/13/10
Pully definately sticks out too far since it looks >>>
ZUL8TR
06:53:00 04/13/10
Woody75 (Denver)
08:14:46 04/13/10
Re: Is the timing belt sitting correctly on the cam gears? -
twin3037
12:15:17 04/13/10
Also, you can erase the "RE ..." line, so we don't have
zellamay
14:29:49 04/13/10
Did you compare new parts to old parts?
zellamay
21:48:56 04/12/10
Re: Did you compare new parts to old parts?
twin3037
22:54:59 04/12/10
So take them off and do it now, unless someone
zellamay
01:55:12 04/13/10
